Hello
I have this error more than often since the last updates, I can dismiss the pop up and stil play music but for example the volume will be locked during playback, I have to stop the album and launch again every time, its getting very annoying
debug
Audirvana Origin 2.5.7 (20507)
macOS 14.2.1 with 16GB physical RAM
Connected account of : ai
AUTO: /Users/ai/Downloads/Musique
Library database path: /Users/ai/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49347
Last audio device error: Erreur de sélection du périphérique audio : UPnP device disconnected
Active method: UPnP
Preferred device: [UPnP] YAMAHA RX-A6A Model UID:Yamaha Corporation RX-A6A UID:uuid:9ab0c000-f668-11de-9976-c0d7aa79ad20
Selected device:YAMAHA RX-A6A
Manufacturer: Yamaha Corporation
Model name: RX-A6A
Model UID: Yamaha Corporation RX-A6A
UID: uuid:9ab0c000-f668-11de-9976-c0d7aa79ad20
UPnP device at http://192.168.1.72:49154/MediaRenderer/desc.xml
ID 0x0
Volume control: Yes
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: Yes
http-get::audio/l16;channels=2;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmafull
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_192
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/mp4:dlna.org_pn=aac_iso
http-get::audio/mp4:dlna.org_pn=aac_iso_192
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get::audio/3gpp:dlna.org_pn=aac_iso
http-get::audio/3gpp:dlna.org_pn=aac_iso_192
http-get::audio/3gpp:dlna.org_pn=aac_iso_320
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
27 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 0
MediaDuration: 0:02:29
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Stop,Play
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 YAMAHA RX-A6A Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-A6A A6A http://www.yamaha.com/ 06D54873 uuid:9ab0c000-f668-11de-9976-c0d7aa79ad20 image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.72/ http://192.168.1.72:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1810Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 YAMAHA RX-A6A Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-A6A A6A http://www.yamaha.com/ 06D54873 uuid:9ab0c000-f668-11de-9976-c0d7aa79ad20 image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.72/ http://192.168.1.72:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1810UPnP devices found : 2
Device #0: ID 0x0 : LG OLED65CX
UID: uuid:b669bb1d-c1be-d319-4d7b-7da5b90c93f5
Manufacturer: LG Electronics.
Model name: LG TV
Device #1: ID 0x0 : YAMAHA RX-A6A
Location: http://192.168.1.72:49154/MediaRenderer/desc.xml
Model name: RX-A6A
Max. memory for audio buffers: 8190MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Device #0: ID 0x48 Haut-parleurs MacBook Air
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs MacBook Air
Chromecast devices found : 1
Device #0: Freebox Player POP
Model name: Freebox Player POP
