My Lyngdorf MP60 2.1 had been showing up as a DLNA output after Audirvana Studio was opened first. Now, I’m getting an error that Dpnp device is was disconnected.
Error selecting audio device: UPnP device disconnected
Audirvana Studio 2.8.1 (20801)
macOS Version 14.4 (Build 23E214) with 16GB physical RAM
Connected account of : Charles Feathers
Sync list: 0 folders
Library database path: /Users/charlesfeathers/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 713
Listening on 127.0.0.1 on port 49169
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Last audio device error: Error selecting audio device: UPnP device disconnected
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
[UPnP] MP-60-7c7438
Model UID:Lyngdorf MP-60
UID:uuid:887158fb-7ad9-46fe-b6ca-e7f2e3543acf
Active Sample Rate: 48kHz
Selected device:MacBook Air Speakers
Model name: Apple Inc. MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
ID 0x4d
Stream ID 0x4e 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4d MacBook Air Speakers
Model UID: Speaker
Device #1: ID 0x31 Aggregate Device
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Aggregate Device
Chromecast devices found : 2
Device #0: Living Room Display
Model name: Google Nest Hub
Device #1: Family Room Display
Model name: Google Nest Hub Max
As you have posted previously using the Lyngdorf MP60 I assume this was working until recently? If so you need to ask what has changed… immediately prior to your issue did you update Lyngdorf firmware? Update macOS? Update Audirvana? If the answer is yes to any it may help locate where a possible issue lies. A few other obvious suggestions which I am sure you have done already…
Powered everything off at the socket (Mac, Network, Lyngdorf etc) Then powered back on starting with Network, then Mac, then audio devices.
Reset the Lyngdorf to factory defaults and re-set up from scratch.
I completed your suggestions and I still get this error: Error selecting audio device: UPnP device disconnected
Lyngdorf MP60 2.1 needed update. It is connecting for now. Thanks for your suggestions.
Good to hear that. Enjoy your music.
Same problem with Yamaha RX-A860. No update available. Everything works fine and suddenly stops: the DLNA amp is disconnected. What can I do ? I have no problem when listening Qobuz through Yamaha MusicCast.
Here is the debug info (when playing again after a crash):
macOS 13.6.6 with 16GB physical RAM
Connected account of : Anne-Sophie Godfroy
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/annesophie/Music/iTunes AS
AUTO: /Users/annesophie/Music/Qobuz
iTunes/Music library synchronization: last synchronized on Sat Dec 30 19:51:23 2023
Library database path: /Users/annesophie/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 6122
Listening on 127.0.0.1 on port 52207
UI theme: light
Font size: regular
Language: Français
Streaming
Ma Musique
Radios
Podcasts
Startup view: Ma Musique : Albums
Number of paired remotes: 2
Active method: UPnP
Preferred device: [UPnP] Pièce Principale Model UID:Yamaha Corporation RX-A860 UID:uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd
Currently playing to UPnP device at 24 bits 96kHz
Selected device:Pièce Principale
Manufacturer: Yamaha Corporation
Model name: RX-A860
Model UID: Yamaha Corporation RX-A860
UID: uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd
UPnP device at http://192.168.1.10:49154/MediaRenderer/desc.xml
ID 0x0
14 available sample rates up to 192000Hz
8000
11025
12000
16000
22050
24000
32000
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: Disabled
Avoid RAW PCM streams: No
http-get::audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL
http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192
http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/mpeg:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 32kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 64kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 22.05kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 24kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 16kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 11.025kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 12kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 8kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:08:52
CurrentURI: http://192.168.1.18:49152/audirvana/audio_f_18.wav
CurrentURIMetadata: dc:titleI. Allegro</dc:title> dc:creatorIsabelle Faust</dc:creator> upnp:artistIsabelle Faust</upnp:artist> <upnp:author role=“Composer”>Wolfgang Amadeus Mozart</upnp:author> upnp:albumArtURIhttp://static.qobuz.com/images/covers/fc/f5/jchi8z108f5fc_600.jpg</upnp:albumArtURI> upnp:albumMozart: Violin Concertos Nos. 1-5; 2 Rondos</upnp:album> upnp:originalTrackNumber2</upnp:originalTrackNumber> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.18:49152/audirvana/audio_f_18.wav
nextURI: http://192.168.1.18:49152/audirvana/audio_f_21.wav
nextURIMetadata: dc:titleII. Andante cantabile</dc:title> dc:creatorIsabelle Faust</dc:creator> upnp:artistIsabelle Faust</upnp:artist> <upnp:author role=“Composer”>Wolfgang Amadeus Mozart</upnp:author> upnp:albumArtURIhttp://static.qobuz.com/images/covers/fc/f5/jchi8z108f5fc_600.jpg</upnp:albumArtURI> upnp:albumMozart: Violin Concertos Nos. 1-5; 2 Rondos</upnp:album> upnp:originalTrackNumber3</upnp:originalTrackNumber> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.18:49152/audirvana/audio_f_21.wav
PlayMedium: NETWORK
Current transport actions:
Stop,Pause,Seek,X_DLNA_SeekTime,Next,Previous
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Pièce Principale Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-A860 A860 http://www.yamaha.com/ 06ED71A3 uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.10/ http://192.168.1.10:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1925Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Pièce Principale Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-A860 A860 http://www.yamaha.com/ 06ED71A3 uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.10/ http://192.168.1.10:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 1925UPnP devices found : 1
Device #0: ID 0x0 : Pièce Principale
Location: http://192.168.1.10:49154/MediaRenderer/desc.xml
Model name: RX-A860
Device #0: ID 0x30 Sortie intégrée
Model UID: AppleHDA:54
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Model name: Apple Inc. Sortie intégrée
Device #1: ID 0x47 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
The Debug info after music just stopped:
No plugin active
Phase = 66%
Tracks with no MBID: 6123
UI theme: light
Font size: regular
Language: Français
Streaming
Ma Musique
Radios
Podcasts
Integer mode: ON
Selected device:Sortie intégrée
ID 0x30
3 available sample rates up to 96000Hz
Stream ID 0x31 2 channels starting at 1
3 virtual formats:
3 physical formats
In the absence of someone chiming in who uses a Yamaha there are a couple of things I would try. I note that you can use the device with Qobuz over Musiccast which is playing OK so it would not appear to be an obvious problem with your network but I would still try a few network and non network related changes to try and solve your problem.
If you are using wireless UPnP I would try a trial with an ethernet connection to your Mac and see whether the UPnP connection is dropped, if not then you know to focus on how you could improve your wireless connection. It is always best if your Yamaha is close to the router to wire that to the router even if the computer is connected to the router over wireless, especially if your Yamaha is close to other wireless sources (i.e TV etc).
I would turn on the UPnP Yamaha settings for “workaround for unwanted playback stops”
I would try after 2 turning on the “avoid raw PCM streams” if that is available in the settings.
I would decrease your buffer from 13312 MB to something like 6000 MB. Your device seems to handle 24/192 kHz music which would make a buffer for a complete classical track of decent length about 2 GB. With your current setting if Audirvana used the maximum permissible size macOS would be short of RAM and would start swapping excessively.
Have you tried removing the iTunes Library sync and just play some Qobuz 24/192 with Audirvana over UPnP and see if this still occurs?
Finally and most importantly I would collect a log file (settings/my account/start log session) and note the time playback stops. I would then send this log file together with the description of the event and time of the dropped connection/playback stop (open log folder and copy the file) to Audirvana support. If the UPnP connection is being dropped the log should potentially help identify the particular error at the time of the UPnP drop-out.
Hopefully someone with a Yamaha RX A860 can contribute with their experience. Once Antoine is back from the Munich High End Show hopefully he will have some more knowledgeable input!
Error back: UpNP device discconnected. This is getting annoying
I’m about to give up on Audirvana and look for a more reliable streaming service.
How are your Mac and Lyngdorf connected to your network? The fact that your Lyngdorf had a problem, was resolved then the problem came back seems to indicate a potential network performance variance issue rather than a setting issue?
Other thing I would try is reducing your max memory buffer allocated to Audirvana to 6000 MB from its current 13312 MB to ensure your OS has sufficient RAM even if Audirvana uses all of its buffer allowance. I would also update macOS after Monday/Tuesday. 14.4 had a few significant issues, 14.5 will be released next week and the latest version is 14.4.1 which was released to fix the most significant bugs introduced in 14.4.
Not enjoyable when encountering intermittent issues. Feel your frustration.
After many years I’m abandoning ship. I’m using WiiM Pro Plus streamer.
I tried all the changes you suggested. Sometimes it works, I have a perfect listening without interruption, sometimes disconnection happens after five minutes, and again and again. Don’t know what to do ! I send you the log file at the next disconnection. There is a need for an update, it happens since the new version of Audirvana studio in March. Before this version, it worked very well.
