This error only occur while trying to play from Tidal a disc containing many discs inside (lets say more than 5 or 6)
Instead of loading all the discs with the tracks Audirvana stop loading saying “Loading more tracks” but nothing happens.
I have experienced this problem in all cases with a multidisc record with more than 5 or 6 discs inside.
I have tried the same discs with the Tidal app and the problem does not occur.
Thanks. The limit to 100 tracks for an album is now removed.
You’ll get the fix in the upcoming 3.1 release (that also brings playback to UPnP devices…)
These albums are missing a track (#2 for the first one, and #10 for the other).
This is an issue at TIDAL (checked with TIDAL web player & app as well).
I am also having problems with the 100 track limit in Tidal on The Rolling Stones in Mono. It is a 15-disc set, and Audirvana says “loading more tracks…” after the second track of disc 9. I appear to be using the most-recent version of the software. Thank you.
I have updated Audirvana 3 to The latest version available today, August 19th, is The 3.0.7, and the problem with album with more of 100 tracks on Tidal, is still present!
For classical music lovers this is a big problem: a lot of new issues are box-set and still now it’s impossibile to listen to all’ tracks of these albums.
For instance:
-Ferenc Fricsay Complete recordings on Deutsche Grammophon (DG)
-Mozart 225 Complete Comcertos (DG, Decca)
-Barenboim -Complete Wagner Operas (Warner)
