As you can see I keep being told to go to Tidal and check my settings. I did try it for two months but cancelled so I have no active subscription!. Any idea how to stop this happening?.
Have you removed credentials (or logged off) from Audirvana?
Hi @Terry,
Can you contact me at support@audirvana.com and indicate the email you used to create your Tidal account?
