Error message when opening playlist
Every so often I get following error message when opening a/any Qobuz playlist from within Studio: “Cannot call StartAt when content generation is in progress”.
I don’t know what triggers the error so I cannot reproduce it at will, but closing and relaunching Studio gets rid of it.
Does someone perhaps know why this happens and tell me if there is something I can do about it?
Many thanks!
If it’s helpful, this is the debug info at the time of the error
Audirvana Studio 2.6.5 (20605)
Windows 11 (22631) with 16GB physical RAM
Connected account of : ano nominus
Available network interfaces:
Ethernet ({33a8495b-f4a9-432f-a1c6-6353b86ed1fa}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Bitdefender Firewall
Replay Gain: by track
Sync list: 1285 folders
[… List of Sync Folders removed because the text was getting too long to be posted on the forum …]
Library database path: C:\Users\Muziek\Documents\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 13349
Listening on 2a02:1810:280c:4800:f98b:1f0f:b405:2430 on port 54913
Active method: UPnP
Preferred device: [UPnP] iFi Model UID:iFi audio iFi audio UID:uuid:48e75bf1-ed45-6dbf-cc31-cabdae7e02d4
Selected device:iFi
Manufacturer: iFi audio
Model name: iFi audio
Model UID: iFi audio iFi audio
UID: uuid:48e75bf1-ed45-6dbf-cc31-cabdae7e02d4
UPnP device at http://192.168.0.195:49152/description.xml
Volume control: Yes
Max volume alert: Disabled
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
NrTracks: 1
MediaDuration: 0:07:34
CurrentURI: http://192.168.0.156:49152/audirvana/audio_f_14.wav
CurrentURIMetadata:
dc:titleOh Mapiano</dc:title>
dc:creatorDJ Melzi</dc:creator>
upnp:artistDJ Melzi</upnp:artist>
<upnp:author role=“Composer”>Tony John Coleman</upnp:author>
upnp:genreDance</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/ja/6x/hdedo7ygu6xja_600.jpg</upnp:albumArtURI>
upnp:albumThe Bomb</upnp:album>
upnp:originalTrackNumber5</upnp:originalTrackNumber>
nextURI: http://192.168.0.156:49152/audirvana/audio_f_15.wav
Better Tomi Agape Tomi Agape Tomi Agape Wereldmuziek http://static.qobuz.com/images/covers/ja/uj/yzcfn14qeujja_600.jpg Never Gunna Be the Same 8 object.item.audioItem.musicTrack http://192.168.0.156:49152/audirvana/audio_f_15.wav
PlayMedium: HDD
Current transport actions:
Next,Previous,Pause,Stop,Seek
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 iFi iFi audio https://ifi-audio.com The Audiophile Music Player iFi audio 1.0 https://ifi-audio.com 42 uuid:48e75bf1-ed45-6dbf-cc31-cabdae7e02d4 image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /upmpd/OHProduct.xml /ctl/OHProduct /evt/OHProduct urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /upmpd/OHInfo.xml /ctl/OHInfo /evt/OHInfo urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /upmpd/OHTime.xml /ctl/OHTime /evt/OHTime urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /upmpd/OHVolume.xml /ctl/OHVolume /evt/OHVolume urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /upmpd/OHPlaylist.xml /ctl/OHPlaylist /evt/OHPlaylist urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /upmpd/OHRadio.xml /ctl/OHRadio /evt/OHRadio /upmpd/presentation.html http://192.168.0.195:49152/
UPnP devices found : 1
Device #0: iFi
Max. memory for audio buffers: 8192MB
Device #0: Speakers (Synaptics HD Audio)
Manufacturer: Synaptics
Model UID: HDAUDIO\FUNC_01&VEN_14F1&DEV_5098&SUBSYS_103C845A&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{72a31f7f-1560-4f9d-acee-60d9b4edf300}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Hi @AnoNom,
Can you send us your audirvana_studio.log file at [email protected]?
to show AppData folder:
Log file was sent to the support mailbox :slightly_smiling_face:
