Error opening Library on Mac
I am using Audirvana Origin in Mac OS.
For some reason, the program now shows as Error Opening Library File.
I tried to create a new one but it seems like it’s taking too long but not create one.
When I re-installed new program, the error remains the same.
Appreciate anyone advise me to how solve the problem.
Thanks.
Hi,
You may have a damaged preferences file.
To reset it, open the Terminal application, and enter the following command:
defaults delete com.audirvana.Audirvana-Origin
