This has been around before, Suggestions…
The obvious is that your DAC is not showing as available or connected… You may try shutting-down your DAC, the router, NAS and then the Mac… Reboot the Mac and wait for the system to load… Power-up the router and wait for it to be available, power-up the NAS wait for all these to boot… then power-up the DAC… Check Audio MIDI Setup to make sure the DAC is selected as the output device and the bit-depth and sample-rate are set for the DAC… Then launch Audirvana…
This only happens at certain times or certain files. As an example if a selected file doesn’t play (above error) I can select another file and it works fine. It sees the Hegel integrated.
Very Confusing
Don’t mind a doing reboot.
Seems to me a this is a possible runtime error (memory stack). Would explain allot.
So… The thing that come to mind for me is… this is centered around making connection with the DAC and your library. over UPnP… I don’t think anybody can troubleshoot your network configuration in the context of Audirvana playback and why it sees the DAC and then does not see the DAC or doesn’t find the actual file data on your NAS… maybe they can give insight as to why the file data is not being found, I hope somebody can see the snag for you if you cannot find it yourself…
I cannot be much help for you in the context of UPnP, because my playback scenario with my 2016 15" MBP, 2.7 GHz Quad-Core Intel Core i7, 16 GB 2133 MHz LPDDR3, (macOS 12.7.6 (21H1320) Monterey) running Audirvana Studio 2.8.3, is Thunderbolt 3 PCIe chassis → USB 3.0 → USB 2.0 → DAC and locally attached library SSD via USB3.0. on isolation from the USB bus power and the DAC at the top of the USB 3.0 bus hierarchy Playback has been flawless.
Perhaps you need some ground-loop isolation on your components… this can precipitate odd behavior due to noise related data corruption… Many Audirvana users are employing fiber-optical for noise isolation.
I have read that some networked audio systems have been interrupted by security cameras on the network being activated, among other similar potentials… and if wifi is involved… all bets are off in regard to reliability…
This issue is unique to Audirvana. I need support to step-in and help figure this out.
Thanks for your support and suggestions.
Does this behavior persist when you make a simple and direct Ethernet connection from the computer (no router/switch, etc) to the H390 and a simple library drive locally attached via USB to the Mac?
I wouldn’t know. I had this set up this way for a long while with no issues with the front end seeing the music files. I have the album/tracks play fine on a another program without issue.
Support I think you need to step in here please…
Hi @moneypit,
Can you send us a copy of the "Debug Info“? You can get it in Audirvana Settings>My account.
Audirvana Origin 2.5.13 (20513)
macOS 14.6.1 with 8GB physical RAM
Connected account of : M
Globally: ON
Max allowed volume: 0.24383
Sync list: 5 folders
AUTO: /Volumes/2xDSD_MUSIC/
AUTO: /Volumes/16BIT_MUSIC/
AUTO: /Volumes/24BIT_MUSIC/
AUTO: /Volumes/DSD_MUSIC/
AUTO: /Volumes/U16BIT_MUSIC/
Library database path: /Users/masonsmacmini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 60139
Font size: regular
Language: English
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] H390D44134 Model UID:Hegel H390 UID:uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
Currently playing to UPnP device at 24 bits 176.4kHz
Selected device:H390D44134
Manufacturer: Hegel
Model name: H390
Model UID: Hegel H390
UID: uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
UPnP device at http://192.168.10.128:38400/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Not automatically detected, user set to MQA Decoder
DSD via PCM 1.0 (Not sure of this setting) Current playing DSD 64 on DAC
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:05:18.000
CurrentURI: http://192.168.10.118:49152/audirvana/audio_f_83.wav
CurrentURIMetadata:
dc:titleDigging In The Dirt</dc:title>
dc:creatorPeter Gabriel</dc:creator>
upnp:artistPeter Gabriel</upnp:artist>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://192.168.10.118:49152/audirvana/artwork_0_83.jpg</upnp:albumArtURI>
upnp:albumUs [DSD]</upnp:album>
upnp:originalTrackNumber7</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400UPnP devices found : 1
Device #0: ID 0x0 : H390D44134
Manufacturer: Hegel
Model name: H390
Max. memory for audio buffers: 2512MB
Local Audio Engine: CoreAudio
Device #0: ID 0x32 LG FULL HD
Manufacturer: GSM
Model UID: 1E6D555B-0000-0000-011A-010380301B78
Model name: GSM LG FULL HD
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Do you get this error even if you reboot your Hegel?
Note that this debug info is showing a different file sample-rate than in your screenshot…
It doesn’t seem you have changed these UPnP settings…
The following media info does not coincide with the file showing in the screenshot you posted…
