Hi, sounds like a familiar error? Don’t know how to get rid of it, happens with every tidal song so far. Listening to my old Sonos again for a few days now, can’t stand it much longer…
Trashed the cache, what else?
Thanks,
Andreas
Thanks,
Andreas
Hello @NLDONG09,
Can you check if you have in this folder /Library/PrivilegedHelperTools the file com.audirvana.SysOptimizerTool in it?
If so, can you remove it and play a track in Audirvāna while Sysoptimizer is enabled?
Thanks, will do. It seems my processor is going through the roof (max capacity) once I start Audirvana. That doesn’t seem right.
Andreas
