Five reboots. Still locked. Pretty pathetic.
Playing a song from library is OK, switching to Qobuz to play a different piece ends up with Error starting device playback.
When it works. songs still stop a few seconds before the end.
Audirvana 3.5.45
SoX to DSD512 with filter type B 8th order
Bandwidth at 0dB = 90.007
Phase = 0
AUTO: E:\backup-003836
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5008MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
Active Sample Rate: 22579.2kHz
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
Device #1: TEAC ASIO USB DRIVER Manufacturer: Model UID: TEAC ASIO USB DRIVER UID: TEAC ASIO USB DRIVER
