Hi. I am using Audirvana 3.5.3 on Windows 10.
I use several USB DAC device on my PC. SoulNote D1, Soekris dac1541 and SP2000.
The problem is, Every Time I run Audirvana and try to play songs (USB DAC, ASIO), Its shows
Error starting device playback
I tried everything. Including
. Restart Audirvana
. Turn on USB device first then run Audirvana
. Run Audirvana first then Turn on USB device
. Do all above at one time
When I using SoulNote D1, the only way to solve it, is to switch the input of my USB DAC (USB > COAX > ASE > USB) when Audirvana is running.
And when i use Soekris dac1541, the only cure is to unplug the usb cable (I dont know why switching input is now working on it).
It is not a BIG problem And I really love Audirvana, but every time This Error just makes me annoying.
If You guys have any solution, PLZ tell me. Thank you a lot!
