i don’t know if the debug information varys by time, but in case it does here is track 3 which won’t play at all
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.3 with 16384MB RAM
Registered to dan gersten
Per track: OFF
AU plugin #0: Effect - Tokyo Dawn Labs TDR VOS SlickEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Jan 29 15:13:55 2020
Library database path: /Users/dan/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
dan.echo
Model UID:f 1200
UID:14-91-38-85-4a-26:output
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x3c dan.echo Manufacturer:f
Model UID:f 1200 UID:14-91-38-85-4a-26:output
1 available sample rates up to 48000Hz
Audio buffer frame size : 15 to 3840 frames
Stream ID 0x3d 2 channels starting at 1
1 virtual formats:
1 physical formats
Device #0: ID 0x3c dan.echo Manufacturer: f Model UID: f 1200 UID: 14-91-38-85-4a-26:output
Device #1: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 soundtouch UID: uuid:BO5EBO5E-F00D-F00D-FEED-10CEA99ECE41 Location: http://192.168.1.186:8091/XD/BO5EBO5E-F00D-F00D-FEED-10CEA99ECE41.xml
