every control of mini player freeze works when you press them but visual are stuck, needs to restore main window and go into mini player to work again.
this happens everytime come on…
this happens when screen saver goes on the problem its visible everytime
so to reproduse it go to miniplayer and let the screensaver goes on and instantly the visuals stop working, you can seek and change volume but blindily if you go to the main view and switch to miniplayer again all works but if the screensaver runs again the problem restarts
