Audirvana 3.5.45
Replay Gain: by album
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\user\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Preferred device: Moode UPNP Model UID:JF Light Industries Moode UPNP UID:uuid:2dfea03c-6f8a-b387-b7bd-0013eff35289
UPnP device at http://192.168.0.101:49152/uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/description.xml
Moode UPNP Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 1
MediaDuration: 0:00:30
CurrentURI: http://192.168.0.100:49152/audirvana/audio_1_22.wav
CurrentURIMetadata:
dc:titleCherry Red</dc:title>
dc:creatorAJ Fullerton</dc:creator>
upnp:artistAJ Fullerton</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/la/6c/nyyt6hncc6cla_600.jpg</upnp:albumArtURI>
upnp:albumThe Forgiver and the Runaway</upnp:album>
upnp:originalTrackNumber9</upnp:originalTrackNumber>
nextURI: http://192.168.0.100:49152/audirvana/audio_0_23.wav
nextURIMetadata:
dc:titleNever Was</dc:title>
upnp:originalTrackNumber10</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Moode UPNP JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.4.12 libupnpp 0.19.1 image/png 64 64 32 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/icon.png /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/presentation.html uuid:2dfea03c-6f8a-b387-b7bd-0013eff35289 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Info-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Info-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Time-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Time-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Volume-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Volume-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Credentials-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Credentials-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Credentials-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Playlist-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Radio-1.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Radio-1 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Product:2 urn:av-openhome-org:serviceId:Product /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/urn-av-openhome-org-service-Product-2.xml /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/ctl-urn-av-openhome-org-service-Product-2 /uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/evt-urn-av-openhome-org-service-Product-2UPnP devices found : 1
Device #0Moode UPNP UID: uuid:2dfea03c-6f8a-b387-b7bd-0013eff35289 Location: http://192.168.0.101:49152/uuid-2dfea03c-6f8a-b387-b7bd-0013eff35289/description.xml
Max. memory for audio buffers: 1566MB
Local Audio Engine:WASAPI
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{82beba49-d37a-4a83-90f7-3d801e80c5db}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: D32f-F1 (Intel® Display Audio) Manufacturer: Model UID: D32f-F1 (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2f76a363-353c-44e7-bf24-26adf4f67ace}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
