Same problem here. I’m running AS on two different PCs (Win 10 & Win 11) both with Fabfilter’s Pro-Q3, but none displays any Pro-Q3 real time information. Switching off upsampling and trying Wasapi or ASIO instead of kernel streaming did not help.
Here’s the debug info from the Win 11 machine:
Audirvana Studio 1.11.0 (11100)
Windows 11 (22000) with 32GB physical RAM
Connected account of :
VST3 plugin #0: C:\Program Files\Common Files\VST3\FabFilter Pro-Q 3.vst3
ClassID: 72C4DB717A4D459AB97E51745D84B39D
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
r8brain with Power Of Two upsampling
Sync list: 8 folders
AUTO: \
AUTO: \
AUTO: \
AUTO: \
AUTO: \
AUTO: \
AUTO: \
AUTO: \
Library database path: C:\Users<HIDDEN>\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a02:810d:463f:f25c:91c1:fff0:951e:5644 on port 56579
Max. memory for audio buffers: 8238MB
Headphones (HDV 820)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{4e875be8-3e5d-4bed-bd84-ac8ec975144e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Manufacturer: Sennheiser
Model Name: Unknown manufacturer
Model UID: TUSBAUDIO_ENUM\VID_1377&PID_4001&REV_0002&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4e875be8-3e5d-4bed-bd84-ac8ec975144e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
Local devices found : 5
Device #0: JRiver MC Input (JRiver Media Center) Manufacturer: JRiver Model UID: JRVADHID UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2909934d-7014-44de-a652-91214375bc01}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Headphones (HDV 820) Manufacturer: Sennheiser Model UID: TUSBAUDIO_ENUM\VID_1377&PID_4001&REV_0002&KS UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4e875be8-3e5d-4bed-bd84-ac8ec975144e}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #2: Virtual Cable Input (VB-Audio Virtual Cable) Manufacturer: VB-Audio Software Model UID: VBAudioVACWDM UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{81e6cc43-a230-4fde-b1ff-06c5c40aa0e9}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #3: ASIO Virtual Cable Input (VB-Audio Hi-Fi Cable) Manufacturer: VB-Audio Software Model UID: VBAudioHFVAIO UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{17afc366-0919-4571-9594-da7c79d0ce41}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #4: Surface Pro Speaker (Realtek High Definition Audio(SST)) Manufacturer: Realtek Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0274&SUBSYS_10EC121E&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{99d81fb8-690a-4e25-832d-69b56eab138d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
