Je termine avec mon debug infos :
Audirvana Mac Version 1.2.0 (10020)
macOS 11.4.0 with 8192MB RAM
Connected account: mon.mail.à.moi.que.j’ai@gmail.com (et mon nom)
“Effects plugins ACTIVE in realtime mode”
AU plugin #0: Effet - Sonnox Oxford Inflator ()
AU plugin #1: Effet - Nomad Factory COSMOS ()
AU plugin #2: Effet - Acon Digital Acon Digital Multiband Dynamics ()
AU plugin #3: Effet - Nomad Factory BT Equalizer PEQ2B-3 ()
SoX custom frequencies
Bandwidth at 0dB = 99.5%
Phase = 66%
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/T7 1/TheScreenwriter3/Music/Music/Media.localized/Music
AUTO: /Volumes/Musique/Musique HD
Library database path: /Volumes/T7/TheScreenwriter3/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51262
IFI (BY AMR) IFI (BY AMR) HD USB AUDIO OUTPUT <-- mon DAC.
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Active Sample Rate: 96kHz
Sample rate switching latency: 1s
ID 0x40 iFi (by AMR) HD USB Audio Output
Manufacturer: iFi (by AMR)
Model Name: iFi (by AMR) HD USB Audio Output
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x41 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 7
Device #0: ID 0x6f SyncMaster Manufacturer: SAM Model UID: 4C2DE805-0000-0000-2014-010380100978 UID: 4C2DE805-0000-0000-2014-010380100978 Model Name: SAM SyncMaster
Device #1: ID 0x36 Elgato Wave:3 Manufacturer: Elgato Systems Model UID: Elgato Wave:3:0FD9:0070 UID: AppleUSBAudioEngine:Elgato Systems:Elgato Wave:3:BS45J1A03593:2,1 Model Name: Elgato Systems Elgato Wave:3
Device #2: ID 0x40 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1 Model Name: iFi (by AMR) HD USB Audio Output <-- Mon DAC
Device #3: ID 0x68 Écouteurs externes Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice Model Name: Apple Inc. Écouteurs externes
Device #4: ID 0x62 Haut-parleurs Mac mini Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Haut-parleurs Mac mini
Device #5: ID 0x4b Reincubate Manufacturer: Reincubate Model UID: CamoAudioDevice_ModelUID UID: CamoAudioDevice_UID Model Name: Reincubate
Device #6: ID 0x5c ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
