Bonjour Damien,
ci dessous :
Audirvana Mac Version 1.5.6 (10506)
macOS 11.4.0 with 16384MB RAM
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by track
SW volume control: ON
AUTO: /Volumes/Multimedia/Musique
Library database path: /Users/Matt/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50005
Max. memory for audio buffers: 15360MB
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
ID 0x4c SMSL USB AUDIO
Manufacturer: SMSL
Model Name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
MQA Decoder device
Stream ID 0x4d 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x3d Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0x4c SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1 Model Name: SMSL USB AUDIO
UPnP devices found : 2
Device #0: ID 0x0 TV Salon UID: uuid:17f7de30-f2c7-11eb-a12b-8a8e607f06d5 Location: http://192.168.1.27:38400/MediaServer/rendererdevicedesc.xml
Device #1: ID 0x0 TV Salon UID: uuid:dcce85b5-f2fb-11eb-a7d8-86e4c3a9e22d Location: http://192.168.1.27:38400/MediaServer/rendererdevicedesc.xml
