Hi, I’m facing the same issue,
Audirvana can play DSD files to my Mac speaker, but not my dac, only noises.
Attaching log, please help.
Audirvana Origin 2.3.4 (20304)
macOS 13.3.1 with 32GB physical RAM
Connected account of : Nguyen Duc
Globally: ON
No plugin active
r8brain with 2x upsampling
Replay Gain: by album
SW volume control: ON
AUTO: /Users/nguyend/Downloads/DucMusic
Library database path: /Users/nguyend/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52553
Max. memory for audio buffers: 2704MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Google Inc. FiiO M11 Pro
Model UID:FiiO M11 Pro:2972:0045
UID:AppleUSBAudioEngine:Google Inc.:Exynos:000006962ec4a9e4:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
Selected device:FiiO M11 Pro
Manufacturer: Google Inc.
Model name: Google Inc. FiiO M11 Pro
Model UID: FiiO M11 Pro:2972:0045
UID: AppleUSBAudioEngine:Google Inc.:Exynos:000006962ec4a9e4:1
USB Vendor ID: 0x2972
USB Product ID: 0x0045
ID 0x60
32000
Audio buffer frame size : 116 to 4096 frames
Stream ID 0x61 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 3
Device #0: ID 0x30 C32HG7x
Manufacturer: SAM
Model UID: 4C2D130E-0000-0000-041C-010380462778
Model name: SAM C32HG7x
Device #1: ID 0x60 FiiO M11 Pro
Device #2: ID 0x52 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
macOS is not able to send raw DSD streams. That’s why the DSD over PCM standard has been developed: to send raw DSD in a fake PCM stream.
To identify it as such, there are 8 bit markers in it.
And the presence of these markers doubles the need of bandwidth, thus explaining why on a mac only half of the max DSD rate is available.
If your DAC is compatible with DSD over PCM, you can set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
Hi Antoine,
Thank you for your prompt response,
I did try PCM 1.0 + 100% volumn but didn’t work,
following is debug log, any suggestions?
Globally: ON
No plugin active
Listening on 127.0.0.1 on port 54078
Integer mode: ON
Hog Mode is on
ID 0x60
32000
18 virtual formats:
18 physical formats
Device #0: ID 0x51 C32HG7x
Manufacturer: SAM
Device #2: ID 0x43 MacBook Pro Speakers
Model UID: Speaker
One suggestion, I don’t know where the polarity inversion takes place in Audirvana, but could it be that the dac doesn’t understand the DoP because of that?
Thank you for your response @RunHomeSlow ,
tried to switch replay gain and Mac OS updating, but nothing change or I missed any thing ?
macOS 13.4.1 with 32GB physical RAM
Globally: ON
No plugin active
SoX to DSD64 with filter type B 7th order
Bandwidth at 0dB = 99.5%
Phase = 66%
Listening on 127.0.0.1 on port 61460
Integer mode: ON
Hog Mode is on
ID 0x5c
32000
Stream ID 0x5d 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 4
Device #0: ID 0x5f C32HG7x
Manufacturer: SAM
Device #1: ID 0x51 Duc’s Powerbeats Pro
Model UID: 200b 4c
UID: 84-AD-8D-51-F5-78:output
Model name: Apple Inc. Duc’s Powerbeats Pro
Device #2: ID 0x5c FiiO M11 Pro
Device #3: ID 0x43 MacBook Pro Speakers
Model UID: Speaker
Thank you for your Response,
switched them off but still
Per track: OFF
Phase = 66%
Max. memory for audio buffers: 6724MB
Integer mode: OFF
Actual I/O buffer frame size: 4096
Hog Mode is on
ID 0x5c
32000
18 virtual formats:
18 physical formats
Manufacturer: SAM
Model UID: 200b 4c
Model UID: Speaker
Notes: when the M11S is going to work in the USB DAC mode for the
first time, FiiO’s exclusive USB DAC driver is required. Please download
it on our website and follow relevant instructions to install it.
This is really weird… the M11 doesn’t need a driver for Windows, but requires one for MacOS
For Mac systems, a driver is needed. 1) After connecting the M11S to the Mac computer, click the “NO NAME” folder emerging on the desktop->double click Mac->Mac/MACOS MTP Client->Android File Transfer.dmg. Drag the “Android File Transfer.dmg” to the desktop of the computer. 2) Drag the “Android File Transfer” file to the “Applications” folder and wait for the completion of the copy. 3) Enter “Applications”, and double click the “Android File Transfer”. Then you can manage the files stored in the internal storage of the M11S or the Micro SD card. Notes: The M11S folder will directly pop up the next time it is being connected to the same computer. M11S User Manual.pdf - Google Drive
Got it … Thanks… I somehow missed the DAC playback description in the manual…
So, you must ask yourself why other Audirvana users like myself on MacOS platforms with other DACs, are not experiencing the behavior you are exhibiting on your M11 playing DSDxxx…? … I personally play DSD128 on my 2016 MacBook Pro using Audirvana 2.3.4 via DoP 1.1 with no problem.
DSD128 requires DoP 1.1 enabled… the DoP carrier PCM sample-rate is 352.8kHz.
Make sure the DAC is at the top of your USB bus hierarchy, you can see this in the System Report make sure you are using a High Speed USB 2.0 cable and if you are using a USB hub, try connecting directly from the Thunderbolt output.
When DoP is represented as noise by a DAC then I would assume that the data stream arrives incomplete / not bit perfect.
The bits that should indicate that this is not standard PCM but DoP are not complete. This cloud happen by volume control, by DSP or some other influence from inside or outside Audirvana.
Have you already tried DoP v1.1.
A reinstall of Audirvana?
