I have had Audirvana for several years, it is up to date and I am currently suffering from a couple problems:
-main issue now is that a track will start to play when activated, but no sound after the first minute or so, even though the progress bar shows the track is still running
Software is installed on a 2014 Mac mini that was purchased new in 2018 running OS X 10.13.3
-secondary issue (which may not relate to main issue above) -sound seemed lower in volume/db than I remember by comparison to other sources— but the player software operated. As far as I know, nothing has changed. I did have multiple connections to the same remote, which I disabled, then renewed to a single remote (iPad).
I can post debug info here since I gather Damien is easier reached here? Or should I email him (Hate to bother the guy, especially the day after Xmas).
Debug data as per copy button: willliam hart:
Audirvana Plus rev. 3.2.20 (3704) debug information:
running on Mac OS X 10.13.3 with 4096MB RAM
User preferences:
Remote control: IR: on, Media Keys: on (with volume control: on)
Playlists
Use UTF-8 for all: on
Start playback at launch with audio file: on
Volume knob control in rotation axis
Sample rate converter
SoX with no forced upsampling
Polarity inversion: global=off, per track=on
Volume control
DAC only
Max volume limit = 100.0%
AudioUnits not in use
SysOptimizer enabled:
Priority: Extreme
Spotlight: on
TimeMachine: on
iDevices USB: on
iTunes settings:
iTunes integrated Mode: off
Completely deactivate iTunes playback: on
iTunes volume control: active
iTunes play position control: active
iTunes safe factor: 1
Library settings:
Sync list : 13 folders
Auto: /Volumes/4T Lacie
Auto: /Volumes/4T Lacie/ Paranoid samples
Auto: /Volumes/4T Lacie/ Sabbath SACD samples
Auto: /Volumes/4T Lacie/At The Mountains Of Madness lackfeather
Auto: /Volumes/4T Lacie/Burnt Sugar - Blood On The Leaf
Auto: /Volumes/4T Lacie/Cream Grande
Auto: /Volumes/4T Lacie/Live Evil
Auto: /Volumes/4T Lacie/Self Titled Swirl Rip Schvartz Shabbos S:T
Auto: /Volumes/4T Lacie/Sway_ Outtakes & Live Tracks
Auto: /Volumes/4T Lacie/Swirl RIP Paranoid
Auto: /Volumes/4T Lacie/Terry Plumeri - He Who Lives In Many Places
Auto: /Volumes/4T Lacie/Twice Removed from Yesterday
Auto: /Volumes/4T Lacie/Vol4 Swirl Rip
Database path: /Users/williamhart/Library/Application Support/Audirvana
iTunes Synchronization: inactive
Audio settings:
Hog Mode: on
Direct Mode: off
Integer Mode: on Mode 1
Max Mem for audio buffers: 1024MB
Max Sample rate limit: None
Sample rate switching latency: None
Preferred device: Schiit Eitr Model UID:Schiit Eitr:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14700000:1
Hog Mode is on
ID 0xcb Schiit Eitr Manufacturer:Schiit Audio
Model UID:Schiit Eitr:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14200000:1
Physical (analog) volume control: No
Virtual (digital) volume control: No
Stream ID 0xcc 2 channels starting at 1
18 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Float 192kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 176.4kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 96kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 88.2kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 48kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 44.1kHz
24 physical formats
Local devices found : 4
Device #0: ID 0xbe Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xcb Schiit Eitr Manufacturer: Schiit Audio Model UID: Schiit Eitr:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14200000:1
Device #2: ID 0x2c Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #3: ID 0x37 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
User preferences:
Playlists
Volume control
DAC only
Priority: Extreme
Spotlight: on
TimeMachine: on
iDevices USB: on
iTunes settings:
Library settings:
Audio settings:
Hog Mode: on
Direct Mode: off
Hog Mode is on
18 virtual formats:
24 physical formats
Thanks, all, bill hart
