AO 2.4.0 (20400) macOS 10.14
I just worked on a filterlist and couldn’t find the Artist. Is it missing (at least in the german version)?
No, unfortunately not
Can you send a screenshot of Audirvāna Origin when you want to add a new filter while I can see all of the filter criteria you have?
Yes, I will send you a screenshot on thursday
You can see Album-Künstler and Titel Künstler if look at the filters
After searching for artist and Künstler, I didn’t looked for more. So everything OK
Thank you
