This is my first post. I am totally new to Audirvana app.
My Mac runs Audirvana 3.5.33 on OS Mojave 10.14.6.
I am attempting to create a smart playlist for all items added in the past 3 days. I am able to create this playlist, but it doesn’t seem to work. It’s just empty. When I create a similar smart playlist for the past 7 days, it shows contents of my entire library.
Am I doing something wrong? I’d be grateful for any pointers.
I find Audirvana’s interface seriously unintuitive in comparison with most Mac software on the market.
BTW, Is there any manual available for version 3? Is there any way to contact Customer Support?
In case you wonder, I started with just one criterium: “Added Date”. When this didn’t work, I added the “Last modified Date”, but that didn’t work either.
Any smart list with dates more than 6 days back show my entire library.
Hi, @Antoine - Thank you for the info about Customer Support.
FYI: In the Debug Info below, I have obfuscated some personal info with this string: •••
Audirvana Mac Version 3.5.33 (3563)
macOS 10.14.6 with 16384MB RAM
Registered to "•••"
Manual: (OFFLINE) /Volumes/G-OPPO-main/2-CLASSICAL
Library database path: /Users/•••/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12032MB
Speaker
Model UID:USB2.0 High-Speed True HD Audio:0D8C:0004
UID:AppleUSBAudioEngine:C-Media Electronics Inc.:USB2.0 High-Speed True HD Audio:40110000:1
Sample rate switching latency: 4s
ID 0x2f Speaker Manufacturer:C-Media Electronics Inc.
Model UID:USB2.0 High-Speed True HD Audio:0D8C:0004 UID:AppleUSBAudioEngine:C-Media Electronics Inc.:USB2.0 High-Speed True HD Audio:40110000:1
Stream ID 0x30 2 channels starting at 1
18 virtual formats:
24 physical formats
Local devices found : 3
Device #0: ID 0x34 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:120 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x27 Display Audio Manufacturer: Apple Inc. Model UID: Display Audio:05AC:1107 UID: AppleUSBAudioEngine:Apple Inc.:Display Audio:1816039B:2,1
Device #2: ID 0x2f Speaker Manufacturer: C-Media Electronics Inc. Model UID: USB2.0 High-Speed True HD Audio:0D8C:0004 UID: AppleUSBAudioEngine:C-Media Electronics Inc.:USB2.0 High-Speed True HD Audio:40110000:1
UPnP devices found : 1
Device #0: ID 0x0 [TV] Living room UID: uuid:c02b2218-ff59-44c2-849b-ef7e8edb329b Location: •••
