I am currently using a MacBook Pro (late 2013) that is hard-wired to the ethernet. Music is supposed to be streamed to my Hegel H120 which does not support MQA decoding. Actually the set-up works fine. However, the first song of some MQA albums is not played. I have to restart Audirvana in order get it back workin. For example, “Bruckner: Symphonies No. 4 - No. 9 (Berliner Philharmoniker, Herbert von Karajan)” has this issue. For some reason the first song is not played…
Any ideas to solve this issue are highly appreciated…
Ralf
P.S.
The Hegel has the newest firmware installed.
— DEBUG —
macOS 11.1.0 with 8192MB RAM
Die Testversion verwendet eine Demo-Lizenz
AUTO: /Volumes/Musik/Musik HQ
Library database path: /Users/Ralf/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Login failed
Preferred device: HEGEL Model UID:Hegel HEGEL UID:uuid:1cfb18fe-1dd2-11b2-99c9-8f57da743e33
UPnP device at http://192.168.178.67:38400/description.xml
ID 0x0 HEGEL Manufacturer:Hegel
Volume control: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:03:49
CurrentURI: http://192.168.178.31:50002/m/NDLNA/77877.flac
CurrentURIMetadata:
dc:title03 - Never Gonna Make It (feat. Steve Houben)</dc:title>
upnp:artistMelanie De Biasio, Teun Verbruggen, Axel Gilain, Pascal Paulus, Pascal Mohy</upnp:artist>
upnp:albumA Stomach Is Burning (feat. Steve Houben)</upnp:album>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
<upnp:albumArtURI dlna:profileID=“JPEG_TN” xmlns:dlna=“urn:schemas-dlna-org:metadata-1-0/”>http://192.168.178.31:50002/transcoder/jpegtnscaler.cgi/ebdart/77877.jpg</upnp:albumArtURI>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 QPlay:2 urn:schemas-upnp-org:device:MediaRenderer:1 HEGEL Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1cfb18fe-1dd2-11b2-99c9-8f57da743e33 http://192.168.178.67 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay.xml /QPlay /QPlay/eventSub http://192.168.178.67:38400UPnP devices found : 1
Device #0: ID 0x0 HEGEL UID: uuid:1cfb18fe-1dd2-11b2-99c9-8f57da743e33 Location: http://192.168.178.67:38400/description.xml
Max. memory for audio buffers: 3562MB
Device #0: ID 0x31 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
