Fixed volume to the maximum
good evening, I’m desperate, audirvana has always worked well, but today when I select a track the output volume is at maximum, it also bypasses my pre, as if it were a fixed output. is there any way to solve? until yesterday it worked correctly, I change the volume with my pre, now it is as if it is bypassed and the signal that reaches the speakers is at very high volume
Can you share more info about your setup? How the things are connected?
I have windows 10 connected via usb to an analogue audio dac, connected in turn to a classé pre and final. I repeat until yesterday I could raise or lower the volume from the classé, instead now the output is fixed at maximum volume from the oc, I can only decrease it with the volume control software, while from the preamp, it makes no difference
Check if you’ve put the Classé pre in AV bypass mode.
