From Qobuz Club:
Update April 9th 2026
We’ve just performed a cache purge with our CDN, which should resolve the issue for most tracks, including those not streamable via partner apps or Qobuz Connect.
If you previously experienced issues with specific tracks, we’d really appreciate it if you could try again and let us know if everything is now working properly, your feedback helps us. Thanks !
