Sync list: 0 folders
Library database path: /Users/imac/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
TIDAL: Connected as PREMIUM
Max. memory for audio buffers: 3072MB
FOSTEX USB AUDIO HP-A4
Model UID:FOSTEX USB AUDIO HP-A4:1019:0011
UID:AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1
Active Sample Rate: 192kHz
ID 0x47 FOSTEX USB AUDIO HP-A4 Manufacturer:FOSTEX
Model UID:FOSTEX USB AUDIO HP-A4:1019:0011 UID:AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1
7 available sample rates up to 352800Hz
Stream ID 0x48 2 channels starting at 1
28 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
42 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
Device #0: ID 0x34 Salida integrada Manufacturer: Apple Inc. Model UID: AppleHDA:50 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x47 FOSTEX USB AUDIO HP-A4 Manufacturer: FOSTEX Model UID: FOSTEX USB AUDIO HP-A4:1019:0011 UID: AppleUSBAudioEngine:FOSTEX:FOSTEX USB AUDIO HP-A4:00001:1
UPnP not started
