Hi to all,
I am having a hard time with Audirvana studio which I am currently testing along with Qobuz. As I am in the process of deciding whether or not I am going to subscribe to one and/or the other, I browse a lot the Qobuz catalog and I am tempted to skip a title or an album to listen to another one. Then most, il not all the the time, Audirvana studio stop playing the new title I picked, and I have to restart it to be able to listen music. It does not come from Qobuz, since I can’t read either titles of my personal library.
What am I doing wrong ? Thanks in advance for your help.
Audirvana Studio 2.2.3 (20203)
macOS Version 13.2 (assemblage 22D49) with 16GB physical RAM
Connected account of : Didier Thomas
AU plugin #0: Effet - Apple AUNBandEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 3 folders
AUTO: /Volumes/EINSTEIN/Fichiers Audio/Classique
AUTO: /Volumes/EINSTEIN/Fichiers Audio/Jazz
AUTO: /Volumes/EINSTEIN/Fichiers Audio/Pop
iTunes/Music library synchronization: last synchronized on Wed Feb 8 15:40:54 2023
Library database path: /Users/didierthomas/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51530
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
HIFIMAN HIFIMAN-EF400
Model UID:HIFIMAN-EF400:2FC6:F824
UID:AppleUSBAudioEngine:HIFIMAN:HIFIMAN-EF400:F030:1
Active Sample Rate: 192kHz
Selected device:HIFIMAN-EF400
Manufacturer: HIFIMAN
Model name: HIFIMAN-EF400
Model UID: HIFIMAN-EF400:2FC6:F824
UID: AppleUSBAudioEngine:HIFIMAN:HIFIMAN-EF400:F030:1
USB Vendor ID: 0x2fc6
USB Product ID: 0xf824
ID 0x10ba
Stream ID 0x10bb 2 channels starting at 1
24 virtual formats:
36 physical formats
Local devices found : 5
Device #0: ID 0x10c1 LG HDR 4K
Manufacturer: GSM
Model UID: 1E6D0677-0000-0000-0A1E-0103803C2278
Model name: GSM LG HDR 4K
Device #1: ID 0x10ba HIFIMAN-EF400
Device #2: ID 0x10d0 BlackHole 2ch
Manufacturer: Existential Audio Inc.
Model UID: BlackHole2ch_ModelUID
UID: BlackHole2ch_UID
Model name: Existential Audio Inc. BlackHole 2ch
Device #3: ID 0x1104 Haut-parleurs Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs Mac mini
Device #4: ID 0x10e0 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
UPnP devices found : 1
Device #0: ID 0x0 : Décodeur TV UHD
UID: uuid:00ababad-7947-1048-8a00-a89a93f030c6
Manufacturer: SoftAtHome
Model name: SoftAtHome Media Renderer
