I’m experiencing problems streaming gaplessly via UPnP to my stereo Devialet Phantoms. I’ve reached out to Devialet, and their solution is to use another player…
I’m a Mac user that streams via Tidal HD. The Mac is connected via ethernet to the Devialets.
I like the sound of Audirvana and hope there is a fix.
Hi Damien. Yes, I am using DOS 2. All firmware is the latest version.
For the moment DOS2 do not support gapless playback with Audirvana but it will be implemented in a future update of DOS2.
Thanks for the information, Damien.
Hi, I just made the same setup and experiencing gaps between mixed tracks. Any word on the DOS2 update?
Using MacBook Pro Audirvana & Tidal into Devialet Phantom Reactors
Thanks!
Hello @kurz, we didn’t had feedback from them about it but they will communicate about the firmware update as soon as it will be ready.
Hello @Damien3 Damien,
New to Audirvana and already loving it! Great work, it simply sounds better.
Any news on this topic “gapless phantom”? This is quite a deal, as many album take advantage of this method…
Thank you
(Windows & qobuz on Phantoms)
Hello @soulwaix,
no news from them for the moment, make sure to contact Devialet support about it to have the latest news.
