I’m sure I am not the only one organizing the library by genres that very often serve as the first step at deciding what I will listen to.
Therefore the tab organisation in the LIBRARY and FAVORITES make little sense.
- It should probably go descending not ascending (GENRE ARTIST ALBUM TRACKS)
- As there is enough GUI real-estate left to the right of the present tabs filters could appear in the same line and not in another vertical column.
And btw - on Mac the filter column list gets cut off despite having tons of space available below.
