macOS 11.2.3 with 8192MB RAM
Licence enregistrée pour SCP PIRIOU METZ NICOLAS
iZotope SRC with Power Of Two upsampling iZotope SRC filter parameters
Steepness = 97
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 175
Phase = 100%
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/music/Discothèque
iTunes/Music library synchronization: last synchronized on Sat Apr 3 21:29:34 2021
Library database path: /Users/guillaumenicolas/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4736MB
YAM
Model UID:00:A0:DE:A3:9A:72-5955189958065-airplay
ID 0x30 Sortie intégrée Manufacturer:Apple Inc.
Model UID:AppleHDA:129 UID:AppleHDAEngineOutput:1B,0,1,2:0
2 available sample rates up to 48000Hz
Stream ID 0x31 2 channels starting at 1
2 virtual formats:
6 physical formats
Device #0: ID 0x30 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:129 UID: AppleHDAEngineOutput:1B,0,1,2:0
UPnP devices found : 1
Device #0: ID 0x0 YAM UID: uuid:5f9ec1b3-ed59-1900-4530-00a0dea39a72 Location: http://192.168.0.45:8080/MediaRenderer/desc.xml
