Several songs from 8 of my albums still appear in my Audirvana library even though I have deleted the synchronization link under Preferences. Audirvana sees these files in the correct folder on my Synology NAS.
Yesterday, I noticed that 2 of my albums had extra copies of some songs. I tried to fix this problem by deleting the plist files from my Mac’s library, but that did not work. Then, I moved those 2 albums from the linked folder on my NAS and put them in a different folder on the NAS. After that, I synched the library again. This approach did not fix the problem either.
After reading someone else’s issue today, I checked the Console app on my Mac mini, but did not see any errors relating to Audirvana. Here are the Audirvana debug data:
macOS 10.13.6 with 16384MB RAM
Registered to [deleted by Elephen]
Sync list: 0 folders
Library database path: /Users/Elephen/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Benchmark DAC2 USB 2.0 Audio Out
Model UID:Benchmark DAC2 USB Audio 2.0:1781:0E4F
UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x28 Benchmark DAC2 USB 2.0 Audio Out Manufacturer:Benchmark DAC2
Model UID:Benchmark DAC2 USB Audio 2.0:1781:0E4F UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1
Stream ID 0x29 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 5
Device #0: ID 0xd1 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:35 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xc3 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:35 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0
Device #2: ID 0x28 Benchmark DAC2 USB 2.0 Audio Out Manufacturer: Benchmark DAC2 Model UID: Benchmark DAC2 USB Audio 2.0:1781:0E4F UID: AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 2.0:0000:1
Device #3: ID 0x31 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #4: ID 0x3c Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
UPnP devices found : 1
Device #0: ID 0x0 XBR-49X900E UID: uuid:23456789-1234-1010-8000-702605422DA5 Location: http://192.168.1.105:52323/MediaRenderer.xml
I appreciate whatever help you can offer. Thank you.
