The last couple of day’s I’ve noticed weird noises comming from my surround back speakers when playing stereo tracks. Some of these noises are from the the track and some sound very glitchy. Normal all stereo track only play on the front speakers. This is only with Audirvana. I have no problems with other players like VLC or Itunes.
Hello @LaZyLiFe,
Can you send me a copy of the “Debug Info” while connected to your DAC? You can get it in Audirvana Settings>General>Debug Info
Audirvana Mac Version 3.5.29 (3559)
macOS 10.13.6 with 4096MB RAM
Registered to XXXXXXXXXXXXXXXX
Replay Gain: by track
Sync list: 17 folders
AUTO: /Volumes/LaCie/WAV-FLAC Music/7" Singles
AUTO: /Volumes/LaCie/WAV-FLAC Music/Afro
AUTO: /Volumes/LaCie/WAV-FLAC Music/Compilations
AUTO: /Volumes/LaCie/WAV-FLAC Music/Country & Western
AUTO: /Volumes/LaCie/WAV-FLAC Music/Electro
AUTO: /Volumes/LaCie/WAV-FLAC Music/Folk
AUTO: /Volumes/LaCie/WAV-FLAC Music/Hawaiian & Exotica
AUTO: /Volumes/LaCie/WAV-FLAC Music/Italian
AUTO: /Volumes/LaCie/WAV-FLAC Music/Jazz & Blues
AUTO: /Volumes/LaCie/WAV-FLAC Music/Kids
AUTO: /Volumes/LaCie/WAV-FLAC Music/Latin
AUTO: /Volumes/LaCie/WAV-FLAC Music/Monstera Deliciosa
AUTO: /Volumes/LaCie/WAV-FLAC Music/Musicals & Film Scores
AUTO: /Volumes/LaCie/WAV-FLAC Music/Pop & Rock
AUTO: /Volumes/LaCie/WAV-FLAC Music/RNB & RAP
AUTO: /Volumes/LaCie/WAV-FLAC Music/Reggae & Dub
AUTO: /Volumes/LaCie/WAV-FLAC Music/Turkish & Arabic
Library database path: /Users/lazyhome/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
HDMI
Model UID:AppleHDA:3
UID:AppleHDAEngineOutputDP:8,5,1,0:0:{CB3D-0E61-00000000}
ID 0x2f HDMI Manufacturer:Apple Inc.
Model UID:AppleHDA:3 UID:AppleHDAEngineOutputDP:8,5,1,0:0:{CB3D-0E61-00000000}
7 available sample rates up to 192000Hz
32000
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x30 8 channels starting at 1
14 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
42 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x3d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x2f HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{CB3D-0E61-00000000}
Device #2: ID 0x2a USB AUDIO CODEC Manufacturer: BurrBrown from Texas Instruments Model UID: USB AUDIO CODEC:08BB:29C0 UID: AppleUSBAudioEngine:BurrBrown from Texas Instruments:USB AUDIO CODEC:6400000:1
Since you have upsampling activated, can you change this settings to “Power fo 2” or deactivate it?
To change your audio settings you’ll need to stop your audio (the square icon)
