Greetings and informations about Studio
Ok, I see now. you can stream from your roon core device to your mobile device.
I use Audirvana through a Hi-res BT transmitter to my BT heaphones and speakers, controlling Audirvana from my phone. Which amounts to the same thing.
Atoll ms120 is connected by Lan cable. The Macmini is connected by Lan cable. The iPad is under same network
But I can’t see the Atoll
Silly question but …
I take it that the Mac and Atholl are both connected to the router or a switch , not LAN between the 2 devices ?
Mac > Ethernet > router > Ethernet > Streamer
Router ethernet mac and router ethernet atoll
Weird. Did @Antoine already had a look at your debug info?
Who is Antoine?
He is Audirvana Support
How can I get in touch with @Antoine ?
You just did by tagging him. And now you’ll probably have to be patient as it is weekend and he is not at work.
Give him a couple of days, he’s busy but more than willing to help.
He will probably ask you to post your debug info here. And maybe some more experienced people in this community can see something in there as well which causes the problem.
So it might be wise to start with posting that info already.
Well. I can’t see Atoll ms120 in Network preferences of Audirvana.
Is there a specific procedure for make Atoll available under net Upnp?
Yes, the issue is clear. What to do not right away. But the debug info from Audirvãna can be useful. When you go to settings in Audirvãna and then to your account you see a button debug info. When you do that, you can paste the info here in this thread.
Solved, but i don’t know how.
Those are the riddles of cyberspace :wink:
Have you restarted anything like your Atoll or your computer during your troubleshooting?
