And from AllMusic and Wikipedia, multi room has been mentioned but not the Remote app, the AS Remote app is simply that a remote , when installed say on an iPad, it cannot use the iPad playback it is simply an app to control the desktop/server version , thatās a big downer for me . Roon will play direct on the installed device. I then use BT headphones in the garden , AS canāt do this.
Big difference is AS is ONE Zone , Roon is Multi Zone (maybe as many as 20)
Beware , Roon is very demanding on the local network, WiFi often fails and stutters, the buffering in Roon is very low to allow zone sync, I think AS loads tracks in advance.
Roon plays best where the end point is designed with Roon in mind and RAAT installed , check your streamer before you try you could finish up with only AirPlay. AS supports UPnP but can have difficulties with some implementations. The Atoll 120 seems to be Roon Ready.
There are loads of threads on SQ differences , so you pays your money you takes your choice. I personally find there is a level difference which confuses comparisons.
If you are into metadata , Roon is the one , the interlinks from within say a artists bio are great , from any page you can link to other albums, artists etc mentioned on that page.
The simple answer is TRY BOTH, I use both and JRiver as well , if i were to split I would say 90% Roon. The AS UI takes a bit of getting used to and isnāt nearly as flexible as Roon, JRiver is ultra flexible in that you can design your own views with a rules engine.
Both AS and Roon are complex beasts and take a while to get around all the features available so patience is recommended. Roon offers a 14 day demo, AS 30 days but you can subscribe monthly to Roon to āextendā a trial. AFAIK AS is only an annual sub (I stand to be corrected)
Finally there is a significant price difference but you get what you pay for . Not the place to say it but I would favour Roon.
Just my 2p
