Hi. Please find the Debug info.
From pressing “play” till playback start it took 4min. 5sec, and during this time Audirvana “not responding”. Upon track change, no audio issues but UI not responding for 1min. 10sec. When UI is responding, navigation inside the track is without any problems.
Audirvana Mac Version 3.5.33 (3563)
macOS 10.14.6 with 16384MB RAM
AUTO: /Volumes/NAS_xxx/test
Library database path: /Users/xxx/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
AirPods2
Model UID:4c 200f
UID:ac-90-85-06-88-b2:output
Device: 4ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 16 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
ID 0x39 Focusrite Thunderbolt Manufacturer:Focusrite Audio Engineering Ltd.
Model UID:FocusritePCIeDeviceModelUID UID:FocusritePCIe-00001
Audio buffer frame size : 14 to 3072 frames
Multichannel: 4 channels
Channel 2 unused
Channel 3 unused
Number of channels: 4
Simple stereo device: No
Stream ID 0x3a 4 channels starting at 1
6 virtual formats:
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 192kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 176.4kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 96kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 88.2kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 44.1kHz
Device #0: ID 0x2f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x39 Focusrite Thunderbolt Manufacturer: Focusrite Audio Engineering Ltd. Model UID: FocusritePCIeDeviceModelUID UID: FocusritePCIe-00001
