Hey guys! Just wanted to post an update:
yes, its true that I heard about the FMCs (notably on the forums of head-fi), and people have said it seems to have a noticeable difference. Conflicting information about the types of FMC, types of cable, single or multimode, simplex or duplex, etc., basically everything. People are now talking about cables and Finisar modules, that together would cost more than the U18.
I moved things around and plugged the R26 into the router (ethernet), instead of directly to the mac via ethernet. A3.5 and studio seem to be much happier this way, but I still get lots of cutouts, the software loses track of what is currently being played, showing wrong song, wrong time etc. but it happens much less than if R26 connected directly to the computer via ethernet.
So I am finally able to A/B : 1) usb → U18 → i2s → R26 vs 2) ethernet → r26
I ordered some FMCs and cables ($115total) just to test it out (they arrive tomorrow)
However, without the FMCs, I can still hear a difference
With USB and DDC : sound level seems a bit lower, sound seems more defined, instrument separation seems greater, more refined, less bass, sounds more technical
With ethernet: louder sound level, bass more pronounced but a little boomy, a “fuller” or richer sound, but a tad more muddled. More “fun” to listen to
Obviously my opinion or descriptions to others are meaningless, but I do hear a difference. I have those FMCs coming tomorrow, will try.
Even if ethernet +/- fmcs sound better, if I can’t get it to play without stuttering or constant problems playing using Audirvana, I’ll probably just stick to USB. Better sound doesn’t count if it skips all the time (for me - I know others have it working 100%)
