I have the Hansong Stereo Hub provided by Buchardt Audio with their A500 and A700 speakers. I have trouble controlling the device with USB or UPnP. For example when connected via USB and having the Software volume control turned on the volume drops to zero. There are other issues but I want to start with this one. I do have a good support contact at Hansong and at Buchardt.
UPnP does not seem to be a highly valued tool for Buchardt. Anyway I am looking for ideas.
Here is the data log from my Mac mini:
Registered to Robert Fairbairn
Max allowed volume: 82.2917
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/FairMusic/
Library database path: /Users/bobfa/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Stereo Hub
Model UID:Stereo Hub:262A:1828
UID:AppleUSBAudioEngine:Hansong (Nanjing):Stereo Hub:14100000:2
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 44.1kHz
Hog Mode is on
ID 0x29 Stereo Hub Manufacturer:Hansong (Nanjing)
Model UID:Stereo Hub:262A:1828 UID:AppleUSBAudioEngine:Hansong (Nanjing):Stereo Hub:14100000:2
18 virtual formats:
24 physical formats
Local devices found : 3
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x35 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{AC10-40BF-3538344C}
Device #2: ID 0x29 Stereo Hub Manufacturer: Hansong (Nanjing) Model UID: Stereo Hub:262A:1828 UID: AppleUSBAudioEngine:Hansong (Nanjing):Stereo Hub:14100000:2
UPnP devices found : 3
Device #0: ID 0x0 A500 UID: uuid:8a631856-0d04-11eb-ad7b-7f9200f59f04 Location: http://192.168.1.178:38400/description.xml
Device #1: ID 0x0 Humax RVU Client MediaRenderer UID: uuid:MediaRenderer-6C_B5_6B_44_6A_D0 Location: http://169.254.9.16:63445/upnp/xml/devices/MediaRenderer1.xml
Device #2: ID 0x0 Humax RVU Client MediaRenderer UID: uuid:MediaRenderer-08_EB_74_C8_26_AE Location: http://169.254.9.42:63445/upnp/xml/devices/MediaRenderer1.xml
