When using the HDMI interface my Denon AVC-X4700H always shows that all channels are in use. If I configure stereo mode only in Audirvana there is no effect. Always all channels are used. That’s a problem because when hearing stereo music, my receiver is configured not to use my sub woofer. But I never get stereo from Audirvana.
In other words: When switching to stereo output in Audirvana only two channels should be enabled. The same as when switching to two channels in macOS Audio-Midi-Setup - this works.
Following the info from Audirvana for both cases.
Another issue I haven’t had with Audirvana 3.5.50 is that when I map channel 1 and 2 to my 7.1 back surround speakers (Configure speakers in Audio-Midi-Setup and without the stereo option in Audirvana) I was able to hear stereo music with them. With Audirvana Origin there is no sound from my back surround speakers. Please see the third log from Audirvana.
Regards
Swen
Audirvana Origin 1.0.3 (10003)
macOS 10.14.6 with 16GB physical RAM
Connected account of :
r8brain with Power Of Two upsampling
Sync list: 3 folders
AUTO: /Users/Shared/Musik/HighRes Flac
AUTO: /Users/Shared/Musik/iTunes/iTunes Media/Music
AUTO: /Users/Shared/Musik/SA-CD RIP
Library database path: /Users/swen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50019
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 4092MB
APPLE INC. HDMI
Model UID:AppleHDA:88
UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101}
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
ID 0x28 HDMI
Model Name: Apple Inc. HDMI
Model UID: AppleHDA:88
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101}
5 available sample rates up to 96000Hz
32000
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x29 8 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
18 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x36 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x28 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101} Model Name: Apple Inc. HDMI
UPnP not started
APPLE INC. HDMI
Hog Mode is on
ID 0x28 HDMI
32000
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
8 virtual formats:
18 physical formats
UPnP not started
Listening on 127.0.0.1 on port 50971
APPLE INC. HDMI
Hog Mode is on
ID 0x28 HDMI
32000
Channel 0 mapped to 6
Channel 1 mapped to 7
Channel 6 unused
Channel 7 unused
8 virtual formats:
18 physical formats
UPnP not started
