Hello,
i connect my Mac Mini (2011) with HDMI to my
Pionner VSX-LX 503. Mac mini use MacOS Highsierra. But i get only 96kHz Output to my AMP. I use Audirvana 3.5“ with connection to Qobuz. Is it possible to get the full 192kHz ?
Hello,
Hello @Pat-1,
Can you go in your audio midi setup app of Macos and check if you have the 192kHz frequency available? If it’s not the case this means it’s a limitation of your Mac Mini.
Yes, i have check the midi configuration. Only 96kHz.
This then means it’s a physical limitation of the HDMI port. To be sure about this, you can ask Apple if it’s the case for your Mac Mini.
