I bought audirvana like 2 months ago , I can’t play certain song in certain frcuencies , UPnP crashes all the time , I have noise after every song , anyway …
Hello @sebas_dro,
Versión actual: 1.6.1 (10601)
Manual: (OFFLINE) D:\Music
Library database path: C:\Users\seba_\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.0.62 on port 49205
Max. memory for audio buffers: 4764MB
Interfaz SPDIF (2- TE7022 Audio w/ SPDIF)
Model UID:USB\VID_1852&PID_7022&REV_0001&MI_01
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f84e8642-42f8-41cf-9cbd-7fff0f26b676}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Manufacturer: (Audio USB genérico)
Model Name: TE7022 Audio w/ SPDIF
Model UID: USB\VID_1852&PID_7022&REV_0001&MI_01
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f84e8642-42f8-41cf-9cbd-7fff0f26b676}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Simple stereo device: No
Local devices found : 3
Device #0: Philips FTV (Sonido Intel(R) para pantallas) Manufacturer: Intel(R) Corporation Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_2808&SUBSYS_80860101&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5cba4068-5053-4226-9b8e-b5fd457ff8ad}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Altavoces (High Definition Audio Device) Manufacturer: Microsoft Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0235&SUBSYS_17AA3811&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2fe67e7-dbf8-4b95-af01-c649b8064c0d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #2: Interfaz SPDIF (2- TE7022 Audio w/ SPDIF) Manufacturer: (Audio USB genérico) Model UID: USB\VID_1852&PID_7022&REV_0001&MI_01 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f84e8642-42f8-41cf-9cbd-7fff0f26b676}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: TE7022 Audio w/ SPDIF
UPnP devices found : 2
Device #0[AV] Samsung Soundbar Q70R UID: uuid:22571f82-7889-421b-ac44-45df3ce50dc9 Location: http://192.168.0.53:9197/dmr
Device #1H190D43F46 UID: uuid:1d19ac9c-1dd2-11b2-ac46-832424bcafd7 Location: http://192.168.0.50:38400/description.xml
Perhaps an obvious question. How does it work without upsampling?
without upsampling i cant listen MQA 44.1
Is it a Hegel DAC/Amp? I think my Hegel Röst has got the same USB chip.
Do you only got problems with MQA?
yes its a hegel amp the h190 , with files in 88.2 khz too,
upnp crashes all the time and is not the amp because is very stable with spotify and mconncet …
Do you mean that your device is not available in Studio anymore when you play some tracks and need to be restarted to see it again?
yes , after it crashed i have to restart everything to listen again or Change to USB
Is your H190 using the latest firmware of Hegel? If you are using WiFi connectivity, have you try to reset the network setting of your Hegel?
as i said before is not the hegel, i can listen with no problem mconncet and spotify
can you send us your audirvana.log file at support@audirvana.com ?
to show AppData folder:
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-10-97fbc472-c603-9d90-91d0-1166d1d9f4b5
sent!
