I could not get Tidal running through Audirvana, playing audio files worked fine but Tidal wouldn’t work, it kept loading forever
Hi @tahoangan,
I have same problem…Cannot play Tidal ![]()
Hi @kvladimirov,
I saw your private message, can you try to reconnect your Tidal account or check the subscription status on tidal.com?
