I have a late 2014 Mac Mini 8gig ram / 500 gig ssd. I wiped it to use as a music server exclusively.
I have downloaded a trial version of Audirvana and it is up and running.
I will run an AudioQuest Carbon USB to a Benchmark 3 HGC DAC/ Preamp and from there to a Purifi based class D amp. I currently have a Bluesound node 2i running through the Benchmark via digital coax and results are very good.
I wanted to run my iTunes through the Audirvana to optimize my cd collection. My collection is loaded at Apple Lossless.
I am not sure how to best set up my Mac Mini and the audirvana to do this. I have read other threads but I am still unsure. I am a novice at understanding the workings of the mac. I have looked into the midi set up but do not understand it and how to best set it up.
anyway ----- any help from a veteran out there would be appreciated.
Regards, Bob in Puyallup WA
Hello @rohbob,
macOS 10.14.6 with 8192MB RAM
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Fri Apr 2 16:52:19 2021
Library database path: /Users/robertrohrer/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Benchmark DAC2 USB 1.0 Audio Out
Model UID:Benchmark DAC2 USB Audio 1.0:1781:0E4E
UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
Active Sample Rate: 96kHz
ID 0x28 Benchmark DAC2 USB 1.0 Audio Out Manufacturer:Benchmark DAC2
Model UID:Benchmark DAC2 USB Audio 1.0:1781:0E4E UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
Stream ID 0x29 2 channels starting at 1
8 virtual formats:
8 physical formats
Local devices found : 3
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x5f HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{6D1E-0001-01010101}
Device #2: ID 0x28 Benchmark DAC2 USB 1.0 Audio Out Manufacturer: Benchmark DAC2 Model UID: Benchmark DAC2 USB Audio 1.0:1781:0E4E UID: AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
UPnP devices found : 5
Device #0: ID 0x0 Kitchen UID: uuid:9ab0c000-f668-11de-9976-ac44f2830124 Location: http://192.168.0.40:49154/MediaRenderer/desc.xml
Device #1: ID 0x0 Audio Room UID: uuid:9ab0c000-f668-11de-9976-4c1b8634fd6f Location: http://192.168.0.41:49154/MediaRenderer/desc.xml
Device #2: ID 0x0 DP-UB820 UID: uuid:4D454930-0100-1000-8000-FFFFFFFFFFFF Location: http://192.168.0.42:60606/FFFFFFFFFFFF/Server0/ddd
Device #3: ID 0x0 [TV] Samsung 7 Series (43) UID: uuid:8e8456dc-d173-43ca-a2f9-fb9d777c790b Location: http://192.168.0.9:9197/dmr
Device #4: ID 0x0 [LG] webOS TV UM8070PUA UID: uuid:115de6f9-4788-d4f5-aaf9-945540a28e29 Location: http://192.168.0.32:1084/
8 virtual formats:
8 physical formats
As we can see this is I suppose you used the second method of synchronization?
Yes, I used the second method.
do you have any comments on the rest of my attempt to do the until set-up?
Do I have it optimized?
Regards
‘Initial set-up’ I meant to type
You can try to enable upsampling in the audio output settings of Audirvana. You can first try with “Power of 2”. If you have audio issue after enabling it, you then need to deactivate it.
