Hello.
For local files it works normally, but when I run it through Qobuz or the online radio itself it starts playing but after a few seconds the audio disappears and I have to turn the DAC off and on again.
I tested it in Windows and it works perfectly.
Below is the Debug:
Audirvana Studio 2.11.0 (21100)
macOS 10.13.6 x86_64 with 4GB physical RAM
Connected account of : Diego Ubeda
DSP NOT ACTIVE
AUTO: /Users/user/Documents
Sync folders at startup: YES
Sort and display order: pt
Library database path: /Users/user/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 38
Listening on 127.0.0.1 on port 49904
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 1322MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
APL Hi-Fi APL Hi-Fi USB 2.0 Audio Out
Model UID:APL Hi-Fi USB Audio 2.0:249C:9200
UID:AppleUSBAudioEngine:APL Hi-Fi :APL Hi-Fi USB Audio 2.0:0000:1
Active Sample Rate: 192kHz
Selected device:APL Hi-Fi USB 2.0 Audio Out
Manufacturer: APL Hi-Fi
Model name: APL Hi-Fi USB 2.0 Audio Out
Model UID: APL Hi-Fi USB Audio 2.0:249C:9200
UID: AppleUSBAudioEngine:APL Hi-Fi :APL Hi-Fi USB Audio 2.0:0000:1
USB Vendor ID: 0x249c
USB Product ID: 0x9200
ID 0x3b
Max volume alert: Disabled
Unhandled (PCM conversion) with boost gain of 0dB
Stream ID 0x3c 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 3
Device #0: ID 0x27 Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x2e HDMI
UID: AppleHDAEngineOutputDP:3,0,1,1:0:{6D1E-5B55-01010101}
Model name: Apple Inc. HDMI
Device #2: ID 0x3b APL Hi-Fi USB 2.0 Audio Out
Ethernet
Chromecast devices found : 1
Device #0: TV Quarto
Model name: Chromecast
