Help, Audirvana no longer connects to the internet for updates and also to connect to Tidal to which I am a subscriber
I forgot … Mac ios Big sur
Hello @Dino1968,
When you try to click on the button to try to connect to Tidal in Audirvana, do you have your default web browser opening to log to tidal?
whether the default browser is already open or not the behavior is the same.
