Help to add HoloAudio Red as 'OUTPUT DEVICE'
Hello Audirvana users! I just installed Audirvana.
I need help to enable HoloAudio Red as ‘OUTPUT DEVICE’ on my Windows11.
  • I set UPnP for output on Red using browser on my Windows11.
  • ‘SSDP Discovery’ and ‘UPnP Device Host’ are Running on my Windows11.
  • router has UPnP enabled.
  • then I rebooted Red, Windows, and router.
    What else to do? Any help, please?
    Regards, Vadim.
Welcome…
Hello Support!
Thank you for response!
Here is ‘Debug Info’ that shows ‘UPnP devices found : 0’.
Is this issue caused by a Firewall?
Audirvana Studio 2.11.1 (21101)
Windows 11 (26100) x86_64 with 32GB physical RAM
Connected account of : Vadim Peschansky
Available network interfaces:
перемога ({eba1f609-b1ef-4d0b-bc87-21d980782f63}) is PUBLIC
Active profile types: all
Private profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
LOADING/DECODING:
Max audio buffer size: 16384MB
Internal EQ: OFF
Effect Plugins: NOT ACTIVE
Sync list: 0 folders
Sync folders at startup: YES
Sort and display order: en_US
Library database path: C:\Users\VPESCHAN\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 0
Listening on fd93:692a:f9f:1:2881:207:b6e2:763a on port 49809
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 16384MB
Local Audio Engine: WASAPI
H32 (Intel(R) Display Audio)
Model UID:HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9d72ac3f-d7cc-4e9f-b7aa-5eb241a6c706}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Selected device:H32 (Intel(R) Display Audio)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9d72ac3f-d7cc-4e9f-b7aa-5eb241a6c706}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
2 available sample rates up to 48000Hz
Simple stereo device: No
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0256&SUBSYS_10280A52&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{59aeb651-c27d-4524-bc67-ceaac7189c2a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: H32 (Intel(R) Display Audio)
Wi-Fi
Check the Windows network type: it must be Private and not Public
Hi Stefano! Thanks for suggestion, the Windows network type is Private. What else I should look at to add HoloAudio Red as ‘OUTPUT DEVICE’? How to troubleshoot?
  • Try turning off Windows Defender Firewall or allowing inbound communication.
  • Anti-virus programs will sometimes prevent Audirvana from accessing a UPnP endpoint. If your antivirus has a place where you can see what applications are allowed access to the local network and what is being blocked, see if Audirvana is being blocked and allow it access if possible.
Can you send a screenshot of what you have on the HoloAudio Red web configuration page?
