Hi,
I am a new user, just installed Audirvana today, impressive. However, I am having issues with songs hick up (every song). I posting the debug info here. I connect USB from my Mac directly to RME ADI-2 DAC fs. Upsampling all songs to DSD 256 and RME sees it that way, too.
macOS 10.14.6 with 16384MB RAM
SoX to DSD256 with filter type B 7th order
Sync list: 0 folders
Library database path: /Users/macbook/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 14524MB
ADI-2 DAC (59740297)
Model UID:ADI-2 DAC (59740297):2A39:3FD3
UID:AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:1,2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
ID 0x38 ADI-2 DAC (59740297) Manufacturer:RME
Model UID:ADI-2 DAC (59740297):2A39:3FD3 UID:AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:1,2
Stream ID 0x39 2 channels starting at 1
20 virtual formats:
20 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x38 ADI-2 DAC (59740297) Manufacturer: RME Model UID: ADI-2 DAC (59740297):2A39:3FD3 UID: AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:1,2
