HI ,
I have HighResAudio streaming annual subscription. I found that I have to disconnect HighResAudio service and login again everyday. Otherwise, I could not play the album, because the selected album show only the album title and cover art, but no track list.
Best regards
Debug Log as below:
Audirvana Studio 1.13.3 (11303)
macOS Version 12.4 (Build 21F79) with 32GB physical RAM
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: /Volumes/Music-DG/
AUTO: /Volumes/Public/test
Library database path: /Users/david/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53575
HRA-Streaming: Connected as SUBSCRIPTION
LINN PRODUCTS LTD LINN MAIN ROOM:UPNP AV
Model UID:Linn Products Ltd Linn Main Room:UPnP AV
UID:uuid:4c494e4e-0026-0f22-380b-013262290171
ID 0x30 NoMachine Audio Adapter
Manufacturer: NoMachine
Model Name: NoMachine Audio Adapter
Model UID: NMAudioDevice_ModelUID
UID: NMAudioDevice_UID
2 available sample rates up to 48000Hz
Stream ID 0x31 2 channels starting at 1
2 virtual formats:
2 physical formats
Local devices found : 3
Device #0: ID 0x46 Mac Studio扬声器 Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac Studio扬声器
Device #1: ID 0x30 NoMachine Audio Adapter Manufacturer: NoMachine Model UID: NMAudioDevice_ModelUID UID: NMAudioDevice_UID Model Name: NoMachine Audio Adapter
Device #2: ID 0x3b NoMachine Microphone Adapter Manufacturer: NoMachine Model UID: NMAudioMicDevice_ModelUID UID: NMAudioMicDevice_UID Model Name: NoMachine Microphone Adapter
