Hi Damien!
macOS 10.13.4 with 16384MB RAM
Registered to [name]
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Manual: (OFFLINE) /Volumes/Muziek/
Library database path: /Users/SanderKarin/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 11904MB
Built-in Output
Model UID:AppleHDA:33
UID:AppleHDAEngineOutput:1B,0,1,2:0
Sample rate switching latency: 2s
ID 0x32 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:33 UID:AppleHDAEngineOutput:1B,0,1,2:0
5 available sample rates up to 96000Hz
32000
Stream ID 0x33 2 channels starting at 1
5 virtual formats:
20 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x100 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-A204-01010101}
