Gladly! Thanks!
Audirvana Mac Version 3.5.39 (3569)
macOS 10.13.6 with 8192MB RAM
AU plugin #1: Effect - Apple AUParametricEQ ()
AU plugin #2: None
AU plugin #3: None
SW volume control: ON
AUTO: /Volumes/8TB (2016)/Network Music
Library database path: /Users/rogiersmacbookair/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Integer mode: Disabled
Lotus DAC5
Model UID:Lotus DAC5:16D0:ECA1
UID:AppleUSBAudioEngine:PureAudio:Lotus DAC5:14200000:1
Active Sample Rate: 384kHz
ID 0x3b Lotus DAC5 Manufacturer:PureAudio
Model UID:Lotus DAC5:16D0:ECA1 UID:AppleUSBAudioEngine:PureAudio:Lotus DAC5:14200000:1
Audio buffer frame size : 116 to 4096 frames
Stream ID 0x3c 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:114 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3b Lotus DAC5 Manufacturer: PureAudio Model UID: Lotus DAC5:16D0:ECA1 UID: AppleUSBAudioEngine:PureAudio:Lotus DAC5:14200000:1
UPnP devices found : 1
Device #0: ID 0x0 LS50 Wireless home office UID: uuid:5f9ec1b3-ed59-1900-4530-84171500e143 Location: http://10.0.1.8:8080/description.xml
