How delete folder in local library
How can I delete a folder from the local library after restructuring? I believe there was a button to delete the folder in previous versions, but in 2.5.20, it doesn’t appear. The folder remains in a disconnected state even after deleting it from the disk.
Hi @Rafael1
Have you tried re-synching your library, after you’ve deleted the folder?
Hi Ironz.
I’m trying it now. The problem is that, if the library database is large, it takes a long time to sync all the folders. It would be best if I could manually delete and sync at the folder level. I have to wait for it to finish syncing if it still keeps the empty folder in a disconnected state.
Hi Ironz.
Problem solved. It’s due to the language selected in the program interface. In Spanish, the trash can and sync buttons don’t appear. When I change the language to English, everything returns to normal. I can delete the folder and sync at the folder level.
Thank you very much for your attention.
Hi @Rafael1,
Can you send us a copy of the "Debug Info“? You can get it in Audirvana Settings>My account.
Hi Antoine.
I’ve attached the debug info.
I’ve tested English, French, and German, and it works fine. In Spanish, the trash and sync icons don’t appear, as you can see in the images.
Regards.
Debug Info:
Audirvana Origin 2.5.20 (20520)
Windows 10 (19045) x86_64 with 12GB physical RAM
Connected account of : Rafael Valera
Available network interfaces:
Ethernet ({aa573b95-6776-4fee-bd0c-202509a11046}) is private
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
r8brain with 2x upsampling
Sync list: 56 folders
AUTO: E:\Barroco
Manual: (OFFLINE) E:\Clasica\Siglo XXI
AUTO: E:\Clasicismo\Beethoven\Camara
AUTO: E:\Clasicismo\Beethoven\Conciertos
AUTO: E:\Clasicismo\Beethoven\Piano
AUTO: E:\Clasicismo\Beethoven\Sinfonias
AUTO: E:\Clasicismo\Haydn
AUTO: E:\Clasicismo\Mozart
AUTO: E:\Romanticismo\Chopin
AUTO: E:\Romanticismo\Mendelssohn
AUTO: E:\Romanticismo\Schubert
AUTO: E:\Romanticismo\Schumann
AUTO: E:\Siglo XIX
AUTO: E:\Siglo XX
AUTO: F:__N\Pneuma
Manual: (OFFLINE) F:__N\Riccardo Muti - The Complete Warner Symphonic Recordings
AUTO: F:__SACD_Esoteric
AUTO: F:\Arne Nordheim
AUTO: F:\Clasica\Directores\Ferenc Fricsay - Complete Recordings on Deutsche Grammophon Volume 1 Orchestral Works
AUTO: F:\Clasica\Jordi Savall
AUTO: F:\Clasica\Piano\Great Pianists of the 20th Century
AUTO: F:\Karl Böhm
AUTO: H:\2L Recordings
AUTO: H:\ECM
AUTO: H:\Jazz__SACD
AUTO: H:\Jazz\Bill Evans Trio
AUTO: H:\Jazz\Duke Ellington
AUTO: H:\Jazz\VA - Astell&Kern-MQS Blue Note 75th Anniversary Collection (2014)
AUTO: H:\The audiophile society
AUTO: H:\The Essential Stevie Ray Vaughan
AUTO: I:\DG 111 Years
AUTO: I:\Directores\Celibidache
AUTO: I:\Directores\Eduard van Beinum
AUTO: I:\Directores\Erich Kleiber
AUTO: I:\Directores\Igor Markevitch
AUTO: I:\Directores\Jean Martinon
AUTO: I:\Directores\Josef Krips
AUTO: I:\Directores\Karl Böhm - The Symphonies - Beethoven, Brahms, Schubert, Mozart
AUTO: I:\Directores\Manfred Honeck
AUTO: I:\Directores\Otto Klemperer
AUTO: I:\Directores\Riccardo Muti
AUTO: I:\Directores\Sir Adrian Boult
AUTO: I:\Directores\Sir John Barbirolli
AUTO: I:\Directores\Sir Neville Marriner
AUTO: I:\Piano
AUTO: I:\String Quartet
AUTO: I:\The Lost Recordings
AUTO: I:\Varios
AUTO: I:\Viola
AUTO: I:\Violin
AUTO: I:\Violoncello
AUTO: O:__SACD\Herbert von Karajan - Live in Berlin 1953-1969 - Berliner Philharmoniker, Herbert von Karajan (2025) [SACD]
AUTO: O:__SACD\Shostakovich - Complete String Quartets - Mandelring Quartett
AUTO: O:__SACD\Shostakovich - Symphonies- Gergiev, Mariinsky
AUTO: O:\Colecciones\Reinhard Goebel - Complete Recordings on Archiv Produktion
AUTO: O:\Colecciones\Riccardo Muti - The Complete Warner Symphonic Recordings
Sort and display order: es
Library database path: C:\Users\rafav\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.21 on port 54559
Font size: regular
Language: English
My Music
Library
Number of paired remotes: 1
Screen saver disabled: yes
Active method: UPnP
Ethernet
Preferred device: [UPnP] iFi Model UID:iFi audio iFi audio UID:uuid:48e75bf1-ed45-6dbf-cc31-62470e39170b
Selected device:iFi
Manufacturer: iFi audio
Model name: iFi audio
Model UID: iFi audio iFi audio
UID: uuid:48e75bf1-ed45-6dbf-cc31-62470e39170b
UPnP device at http://192.168.1.132:49153/description.xml
Volume control: No
Not automatically detected, user set to MQA Decoder
Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: None
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Next,Previous,Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 iFi iFi audio https://ifi-audio.com The Audiophile Music Player iFi audio 1.0 https://ifi-audio.com 42 uuid:48e75bf1-ed45-6dbf-cc31-62470e39170b image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /upmpd/OHProduct.xml /ctl/OHProduct /evt/OHProduct urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /upmpd/OHInfo.xml /ctl/OHInfo /evt/OHInfo urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /upmpd/OHTime.xml /ctl/OHTime /evt/OHTime urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /upmpd/OHVolume.xml /ctl/OHVolume /evt/OHVolume urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /upmpd/OHPlaylist.xml /ctl/OHPlaylist /evt/OHPlaylist urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /upmpd/OHRadio.xml /ctl/OHRadio /evt/OHRadio /upmpd/presentation.html http://192.168.1.132:49153/
UPnP devices found : 2
Device #0: iFi
Device #1: [TV] Samsung The Frame (55)
UID: uuid:c5485f77-7769-4664-8793-cb2555b45e02
Manufacturer: Samsung Electronics
Model name: QE55LS03RAUXXC
Max. memory for audio buffers: 4052MB
Local devices found : 0
Hi @Rafael1,
When you are using Spanish, do you see the vertical and horizontal scroll in the local settings of Audirvāna?
