Dear Audirvana community,
Is there a way to migrate the whole library with all the playlists from one computer to another without having to export them one by one?
Thanks,
Tamas
Thanks,
Tamas
Close Audirvana.
copy that folder (that is your database of music with your playlists).
copy com.audirvana.Audirvana-Plus.plist and com.audirvana.Audirvana.plist
in that folder (those are A+ software preferences).
Put them in the other Mac at the same place they were.
Restart the new Mac.
Put Audirvana in the Applications folder of the new Mac and start it.
If it is a new Mac and you will not use the other, you can de-authorize before starting
the new one if you have already use your 2 licenses.
For me, it is always a good idea to export all your playlists when they are set up like you want…
so, if a bug occured in your music database and you have to trash it, you don’t lose them
Thanks a lot for your help!
