How much for Signal Processing Toolkit ?
Hello, for the moment I don’t need Signal Processing but there is an option to upgrade with Signal Processing. If I decide to pay for it later, will it be the same price ?
OK, I did not search well. It’s told that there is lighter price if I pay when upgrading.
Price is 90 euros for a regular Signal Processing One time Purchase. Origin Update + Signal Processing is 130 euros. Origin Update alone is 50 euros. So you gain 10 euros if you update + Signal Processing.
If Origin includes/allows VST/AU plugins then just find some of many that are available for free…
There are literally thousands of VST/AU plugins… Many are free or free trial…
If you told us what kind of DSP you are looking for, I am sure many of us could point you in a direction to go…
